French Tandem bike identification!
Slick4d4d
This is a great tandem bike that missed out on years ago, I didn't have the money for it or the space (I still don't have the space). But it recentlycame back on the market and I couldn't pass it up this time! I remember it being an expensive bike and the shop that had it was asking a pretty penny for it, but since I saw it last all the water based decals are all most complete gone and I'd like your guys, and gals, help putting a name to it again. The most unique feature is the wide bottom bar under the pump.
juvela
cycle appears to be one produced for Mel Pinto Imports of Falls Church Virginia
the coat-of-arms transfer on the cycle's head tube is that of the Pinto family -
the machine looks to date from the early-to-mid 1980's
Mel Pinto Imports, or MPI for short, is yet in operation today
company founder passed earlier this year at the age of ninety-seven
do not recognize the manufacturer of the machine. MPI had a long association with Gitane; AFAIK that ended many years ago.
at one point they were also an agent for Urago cycles.
forum member @MauriceMoss may be able to identify the actual producer of the machine....
MPI had numerous house branded products, both cycles and accessories.
fittings -
Stronglight model 99 chainset
Simplex SLJ gear ensemble with Suntour Barcon shifters
MAFAC cantilever brakes
ATOM rear drum brake
Lyotard model Berthet pedals
AFA frame pump
" The most unique feature is the wide bottom bar under the pump."
in frame building terminology this is known as the bottom tube. the oval shape seen here is standard on a Reynolds tubing tandem set. it is widely found on high quality lightweight tandem machines.
here is a forum discussion thread on an example whose owner states it to be from the early 1970's
its downtube exhibits a similar "Mel Pinto Special" transfer as seen on the subject machine -
