I have done this with a very small drill bit, drilling right through the center of the rivet, & it popped right off w/out damaging anything. Might work for you as well! Just take it slow & easy...Good luck!
Go from inside the head tube with a very large screw driver or pipe applying pressure until you get it out enough to grab it with a pliers from the outside and twist counterclockwise while pulling. Of course you can always use @the tinker alternative method ! https://thecabe.com/forum/threads/removing-head-badges-easily.144626/ V/r Shawn
