jeff54: PM edited and posted:
The easiest key for recognition is the spring yoke.
REC.
Ah I see it now but not exactly due to your explanation but because you caused me to look, and look and look again. I have 2 55's a Phantom and deluxe hornet, and both types of the 95 repop 'new and old' cited in photo docs above. . The 55's are Schwinn's "New style forks, perhaps though using 'old style' yoke
So, I guess that's why Schwinn made the repops citing 1954 models then, that's the cut off date for new vs old. Yet those are the only springers I have.
But what I finally noticed is the smoothness of the front of yoke. and maybe it's jogging me old brain's memory, yet it's awfully dark in there. Albeit it seems to me, that, it was probably the smooth yoke we changed out the new styles into. The top area's ovulated yoke front is smooth on the 55's "new style" where as the same area on repop has a very slight, for lack of better word,
indentation, on each side of the front top area of yoke.
Yet, realizing this difference and regarding the Schwinn doc photos I'd posted above, in the same area you can see that, the old style appears to be a photograph of it with smooth surface while new is graphic drawing . That graphic shows two lines on each side of top of yoke which is similar to the 95+ repop differences noted. "Similar" but certainly not on the money as 'new style' on my 95's is smooth too without those lines but slightly different and 'similar'. while the 55's yoke is very smooth and much like "old style"
So and but you also brought an photo of another thing which I was commenting about. The red bike, just like the new style 95+ repop; the pressed flat area for the pivot bolt on fork is freaking off center. Recently I browsed several 50-60's springers and none of them had this off center
defect. That spot is what I recently noticed and why I was searching the net to discover if it's a tell tail of the repops.
So in the krate photo you got, notice how well centered the pivot bolt, that flat pressed spot is centered, it's on the money. Certainly illustrating that, they could misfire on that flat area but, and, as long as the hole was put correctly it doesn't matter much except appearance, balance or aesthetic appeal. .
Yet, noting my 95 'New style' has the misfire press, then ya gotta wonder, is that red bike's fork also a repop? Or, perhaps as, when me was young, dumber and stupid, (not to imply I got any smarter, but perhaps just wiser, [maybe] ) we kids knew that Schwinn's quality changed quite a bit during late 60's into 70's which was why we were changing out the new parts on our 60's sting rays to older parts that were unique, better metal and chrome, that springer on red bike if it is actually 60's it is illustrating this, and them dar repops screwed the pooch too?
I should add, when the krates came out we, (neighbor kids) were not impressed, 1. was because we'd already, save the 5 speed shifter, freaking built em, but even more importantly, believe it or not, the quality was crap in comparison to what we were used-to. .
