Jay81
I'm working on a Rambler motorbike, trying to remove the crank assembly to grease the bearings. I haven't seen one like this before. The hardware does not slide off over the crank arm like I'm used to. There is a little bit of play that feels like the two crank arms come apart, but I can't figure out how. Looked under the bottom bracket and found a small metal plate screwed to the bottom. Took that off and looked inside with a flashlight but can't see anything to remove to get it apart. What do I need to do to get this darn thing apart? Please help!
