Help i.d. bicycle frame
Tino
Mar 4, 2012
247
106
Northern Indiana
#1
Hi guys, I am not sure what I have here. The fenders and wheels are not original to the bike. It is badged as a Hawthorne but it might not be original to the bike either as the rest seems pieced together. The sprocket is a Fauber special. I am hoping somebody can identify the frame and fork based on the following pictures. Thanks Tino
shoe3
In Memoriam
Feb 2, 2011
1,098
898
Springfield, United States
#3
Fork definitely Excellsior! Probably repaint but Excellsior known for green paint schemes.
Likes: dnc1
anders1
1,038
1,145
44
Southern California, USA
#4
This is my Michigan City Excelsior mid 20’s. Paint on your bike definitely looks to me like it was repainted at some point?
Likes: dnc1
anders1
1,038
1,145
44
#5
Only a guess but seems to me that the badge might be correct on an older fix up. Especially if badge holes line up properly. What are the chances you would have found another to fit perfectly back in the day? Just my thoughts...
anders1
1,038
1,145
44
#9
Other guys know much more than I do about these bikes but my guess is that it is what it says it is? Aside from some switched out parts.
anders1
1,038
1,145
44
#10
This picture is off the net, probably belongs to a CABE member. 1925 I think, not exactly like yours but close. Someone else here will know for sure. Keep investing, that is part of the fun. Good luck!
anders1
1,038
1,145
44
#14
Archie Sturmer
Jun 13, 2018
329
239
Los Angeles, CA, USA
#17
The curvy bend (drop bar) looks characteristic Great Western, as does the heavy boss hairpin truss rod.
Excelsior's may have more of a faired yoke (wye) truss rod. See threads on the Fauber-GWM connection.
GW may often have badges such as Adlake, America, Crown, Reading Standard; R/S may have had side-holes.
Catalogs say 20" nominal frame size, but mine is 19-3/8" - and may require Ross 35mm headset cups.
Likes: Goldenindian
shoe3
In Memoriam
Feb 2, 2011
1,098
898
#18
my, bad...on Excellsior....Saw one once with fauber and fork. Great Western looks like a match....they must made for Montgomery Ward ...Hawthorne bicycles.
Archie Sturmer
Jun 13, 2018
329
239
#20
The dogleg cranks might not be GW or Fauber; the chain ring, with 3 arms, may be an older Fauber with a separate hole for the round drive pin.
On my Fauber set, the drive pin hole was in place of one of the more rectangular slots in one of the 3 arms.
A reason that the cranks look askew may be because GWM could have used oversize cranks, (hard to see), with the drive pin further from the shaft, perhaps also requiring oversize cone thread diameters?
Some GWM motorbike ads show a snowflake design, (similar to Iver Johnson & Hawthorne), which GW identifies as R.S. design (Reading Standard).
Likes: anders1
