nycet3
I bought these tools about 2 or 3 years ago in a small lot of bicycle tools. I've been searching high and low, but cab't ID them.
They pivot and are locked in pkace by a steel pin. In the photos you can see one tool with pin engaged, the other without.
A contoured steel block (for shaping/forming?) is screwed down by means of a T bolt.
A friend thought these may be used to straighten bent & dented rim walks. Sounds reasonable, but if anyone knew for sure what these are for, I could begin sleeping regularly. Thanks, Joe.
Whatever they are, they're cool as hell.
(A common razor knife for scale.)
