Help identify
BrianInPA
A few other members have been gracious enough to lend a hand, but we don't have a positive ID yet. Found in northern Ohio under a porch.
Badged as a Speedway Special, serial number looks like F5761U, but really only the 576 are clear. Wheels are 23" diameter, so we think it's a 26" bicycle, and they are 28 spoke. Seat tube is slit on the back. Seat says Scout.
Hope to learn the year and make. Thank you!
SKPC
This one stumps me being a juvenile bike and looking rather complete. Short crank and 26t( 52t) ring~~EDIT=24t(48t) looks original. Fork assembly and badge seem intact also. Hmmm. Could it be a Shelby? Or an Excelsior made ride? Serial # odd for S.C.Co
SKPC
Yes rare if a Shelby. @dave the wave spotted a very Shelby-like characteristic used on most all their bikes, including the pre-Shelby Cycle Co frames 1923 through 1925. The oversized/straight upper seat stay fender bridge. A fat rolled tube mitered & brazed to the stays. Brian, can you take a pic of the bottom of this upper seat stay fender bridge to see if there is a straight rolled/butted joint visible on the bottom? Also, look for a small welding "weep hole" on the bottom of the lower top tube near the down tube. If it is there, take a photo. The 1923-25 Shelby Frame Builders bikes did not sport the flat-sided headset cups that I know of. These came after 25. Not sure these on the OP bike are "flat sided". That badge and rivets sure look untouched to me, but others makers badged "Speedways"? And those truss rods with the bend at the axle hole and early crown/truss support design appear shelby-like but the sprocket no so much...Other Shelby affectionados? @slick @cds2323 @redline1968 @hoofhearted
BrianInPA
Thank you! Let me get a few more detailed pictures and I'll post them up.
