Help identifying a Puch?
HerrOtto
Hello, can anyone tell me what model and what year this Puch (Made in Austria), single speed, coaster rear brake, rod front brake, 700C/28" rims, is? I am guessing from the style of the reflectors, it is late 70's early 80's. Not sure if the seat is original or not but I like the looks of it. Thank you
rhm
I believe the saddle was made in Japan, and dates to the same era, more or less, as the rest of the bike.
Jesper
At times there may be a date code on the reflectors. Some of my older cars have them my bikes do not have any reflectors). Not sure about that saddle being original, I doubt it; but who knows. The "Waffenrad" originally was tied to an arms manufacturer. Maybe Puch/Steyr co-opted the name in later years to indicate a model. The head badge looks to be circa 70s. Is there any date code on the rear hub or other components?
Oilit
I'm with @Jesper , check the rear hub. If it's Sachs, there will be a letter/year code. Earlier Steyr hubs had a two digit number for the year.
Oilit
That's interesting. On the Sears lightweights imported from Austria they went from Steyr hubs to Sachs hubs sometime in the late '60's, but that was for three speeds. You have the first Favorit I've seen, but it's a Czech hub according to Google, so still in the same neighborhood.
juvela
I do not see the Waffenrad in the 1981 Katalog. Is it supposed to be in there?
apologies if catalogue a source of confusion
posted because it is the closest to date suggested was able to locate
thought it might provide some backgrund information of interest
thanks for sharing this example
most of the Puch/Steyr cycles posted to the forum are from the boom era or earlier
we do not see many post-boom products from this maker
rear hub -
front and rear wheel rims appear to be a match so would think hub to be original to cycle
are you able to read any markings on the bicycle's wheel rims?
frame -
head lugs: BOCAMA pattern 81/I
seat lug: BOCAMA pattern H
fork crown: NERVEX pattern Nr. 2
chain stay bridge: ESGE plate style
seat stay bridge: ESGE plate style
pump pegs: NERVEX Ref. 845
steerer: may be the manufacturer's proprietary 26.0mm diameter; do not know it they continued its use this late; if steerer 26.0mm then headset will be special size
rear rack likely to be a May-Weg, or possibly and ESGE
