Hi I am new to all of this and just received a Jc Higgins mens 3 speed. the only numbers I see so far on rear wheel base? is Jc Higgins 50280. any help to model or serial number, perhaps estimated Value. everything works but does need some paint restoration.
Hi I am new to all of this and just received a Jc Higgins mens 3 speed. the only numbers I see so far on rear wheel base? is Jc Higgins 50280. any help to model or serial number, perhaps estimated Value. everything works but does need some paint restoration. View attachment 793892
The shifter is probably a replacement. The original shifter would have been made in Austria, like the hub. But a lot of those three speed hubs closely followed the Sturmey Archer design, or were made under license, so parts often interchange. It's a neat bike, but 3 speed lightweights still sell as used bikes most of the time.
And the serial number is usually under the bottom bracket, but you can date it from the rear hub, if it's original. It looks like yours has the Steyr hub which would be right, late '60's versions used Fichtel and Sachs, but they were badged as "Sears" by then.
