I'm building from the ground up a Whizzer Sportsman. What type and source to buy the headset for the headtube. I'm using the Whizzer Sportsman fork assembly. THX
Good luck on the build. It appears from the picture you are holding a 1999-2003 WC1 engine? If so and it has not been upgraded to the NE5 specs you might want to reconsider investing in a great build with that motor. The stock WC1 engine is well know for its short life span. (I may be wrong so an apology in advance) Just a suggesting to consider.
