DX is the model:
https://bikehistory.org/catalogs/1948.html
Model D97X
All specifications for this model are same as DB97XE described above except that torpedo light, carrier, tank and horn, and truss rods are not included.
(Un equipped)
Standard DX frame. Truss rods and chrome rims available at extra cost. Optional: for Autocycle frame (same as DB97XE model) Order DB97X.
Specifications for Model DB97XE
FRAME-
Fully streamlined design, Schwinn-Built tubing. Removable seat post clamp, built-in kick stand, mud guard and chain guard brackets, dropout rear fork ends.
FORK-
Oval, solid forged steel construction. New patented trussplate.
CRANK SET-
One-piece crank-1" pitch sprocket-cones turned from finest bar steel. Two-point ball bearing races.
FRONT HUB-
Schwinn design. Bearings with large 7/32" balls in retainers. See page 2.
REAR HUB-
New Departure or Bendix coaster brake, Morrow Coaster Brake optional at additional cost.
HEAD SET-
New design with semithrust type lower races. Large 3/16" balls in retainers. Two point contact ball races. See page 28.
HANDLEBAR-
SB26 x 8.
HANDLEBAR STEM-
Standard type.
TANK-
Streamlined, containing horn.
KICK STAND-
Schwinn-Built patented construction. See page 3.
MUD GUARDS-
Deep type formed and reinforced where attached to frame. Semi-tubular braces. Rear braces attached to frame. See page 2.
CHAIN GUARD-
Embossed. Heavy brackets attached to mounting lugs built into frame. See page 2.
CHAIN-
1" x 3/16" roller.
HEAD LIGHT-
Fender torpedo type, self contained.
LUGGAGE CARRIER-
Mounted directly to frame, not on rear axle. Jewel reflector.
TIRES-
26" x 2 1/8" Cord Balloon. Whitewalls at extra cost.
RIMS-
Enameled S-2 Schwinn Tubular. See page 29.
SADDLE-
Mesinger-padded.
PEDALS-
Rubber.
REAR REFLECTOR-
Jewel.
FINISH-
Finest synthetic enamels over heavy prime coat.
Colors:
Light Red, Light Blue or Black, with Ivory Trim. Special colors at extra cost.
D37XE Ladies'
