HEX TUBE HELP
Roadkill
May 7, 2016
189
227
48
Peoria, AZ
#1
My friend has a beautiful 48 Hex Tube Silver King that has garbage aftermarket pedals on it. Does anyone know what pedals would have originally come on this bike? Thanks.
Ride on
Sean
Freqman1
Jul 14, 2009
15,819
16,094
Evans, GA
#4
I second the Torrington 8s as far as what was called for in the literature. That said I believe my original bike has a different pedal but I'll check. V/r Shawn
Roadkill
May 7, 2016
189
227
48
Peoria, AZ
#6
Thanks Shawn. I thought they might have come with the elusive Monark deluxe or supreme pedals. Maybe these were later?
Ride on
Sean
Roadkill
May 7, 2016
189
227
48
Peoria, AZ
#8
Thank goodness they didn't come with those! The light is bad enough. By the catalog T8s will fill the bill. V/r Shawn
Thanks again Shawn. Luckily, it has the pedestal light already.
Ride on
Sean
Freqman1
Jul 14, 2009
15,819
16,094
Evans, GA
#10
@Freqman1 what is the difference between a T8 and T10's. Is it the length of the blocks?
Thanks,
Sean
Blocks and caps are both different. If you do a search here on the forum you should find examples pretty easy. The T10 was used, primarily, on deluxe bikes and the T8, generally, on the lower tier bikes. V/r Shawn
Roadkill
May 7, 2016
189
227
48
Peoria, AZ
#11
Ok. Gonna search more on here. Thanks again for you help Shawn. He also has a dogleg crank on it, from a 35 SK I believe, that won' allow him to run the proper chain guard. Do you know what crank should be on there? A lot of questions, but you usually have a lot of answers. Haha
Ride on
Sean
Freqman1
Jul 14, 2009
15,819
16,094
Evans, GA
#12
Ride on
Sean
Sean,
Without moving a bunch of bikes here are the best pics I can get. I believe the crank is a standard post war Monark crank and could even be a Wald. Here are the pedals on my bike which I believe to be original. Lastly notice the mount of the guard which conforms to the frame of the bike--this is unique to the Hex Tube. Hope this helps. V/r Shawn
Roadkill
May 7, 2016
189
227
48
Peoria, AZ
#13
Sean,
View attachment 717725 View attachment 717727 View attachment 717730 View attachment 717731
Right on Shawn. You da man. He has the correct guard and clamp for the hex tube as well. Thanks so much for the information. I did find a thread on the pedals, and it was full of details. I' hoping someday I can talk him out of this bike. Haha. Thanks again.
Sean
R
removed
Guest
#14
THEY WOULD HAVE HAD EITHER 8'S OR 10'S I'VE SEEN THEM BOTH WAYS BUT THE MONARK "SCRIPTED" PEDALS ARE INCORRECT FOR SURE
