brewerkz
The frame came with a threaded insert/sleeve in the bottom bracket. While removing the square bottom bracket, the sleeve came out of the frame. It appears it was secured with grey epoxy. You can see a hole that line up with the grease fitting.
The frame bb measures 1.475" ID, is the correct size for a bottom bracket like a threadless BAYLISS WILEY 8C BOTTOM BRACKET ? Or has it been oversized for the sleeve?
If its oversized, what is the best way to secure the threaded sleeve back in the frame? epoxy again?
