How do I remove the tank from a Higgins Flightliner?
Take the screw out of the top of the head light bezel, then remove the two on the bottom, pull the bezel forward away from the bicycle.
Then slowly spread the front of the tank apart, it is hinged at the rear, where it sits on the frame tab, when you open it wide enough it will slide forward then out either side of the frame.
