I have a 1953 26 inch frame that has been repainted probably a few times, what would be the best chemical to use to figure out what the original color scheme was for this bike?
I read that aircraft paint remover gel was best, is that too strong?
I've used Easy-Off oven cleaner with good results. What ever you go with, I'd test a small area under the BB shell to see how it reacts and how long it takes to work first.
I've used oven cleaner on a vehicle with a crappy respray before, but not no a bicycle. The result was pretty good. You can use a scotchbrite pad (Green for a lot of coats or grey for just one respray) Be careful and only do small sections at a time. I always kept a water source nearby to rinse if needed.
I have a 1951 Schwinn that has been painted over twice and I am using xylene for the first coat and very fine steel wool and wd-40 for the second. It takes a while but it has the best results for me.
