How to disassemble the crank on a Crescent No.11 1898?
Roger K
I've found a 1898 Crescent No.11 that seemingly hasn't been used the last 90+ years, but still looks OK enough to be back on the road with a little service and new tires.
Here comes an obstacle - I don't know how to take the crank apart without damage to the parts? No place to put a puller..
I guess someone here has done it before?
Roger K
I wasn't paying attention yesterday when I looked at it - there are actually threads for a puller inside the pedal arm - does anybody know the thread, so I can make me a puller?
Archie Sturmer
Interesting contraption.
Any pictures of the pin on the bottom bracket or the knurled lock-nut?
1633686
I had believed that the threaded BB cups were Fauber parts; but it looks like threaded cups without flanges may be Crescent parts.
1633684
Andrew Gorman
Is the crank axle threaded? the arm may screw on or off with the slotted nut as the locknut. Just an idea- I haven't taken one apart myself.
ditchpig
Looking at fig. 3 there doesn't appear to be threads holding that non drive crank arm....maybe just a square shaft? Then looking at the fig. 4 the bearing race looks inboard of the bearing on the non drive side. Soooo....is there a chance that one could tap the axle through towards the drive side once the drive side bottom bracket ring is removed. Just riffin' ?
Kryn
wheelman
I had the same problem when I made mine. It's very difficult to measure the internal threads and the diameter is odd. It's been years but I clearly remember chasing the threads in my lathe several time before i had a good fit and the used my first effort as a pattern to make a more refined copy.
I'm measuring .786 inch outside diameter of the threaded portion of my puller and 32 threads per inch.
