Hub disassembly...?
guzziworksman
This is a hub off an old Japanese bike - I want to take it apart so I can clean the rim/respoke. I can't get either side loose. It's been soaked for days in penetrating oil, heated...and sworn at. There's no rust apparent. Just 60-70 years of being together. The brake drum appears to be a right-hand thread. I would've thought it should be left-handed, given it's on the left side. But the threads say different. No idea on the cog side - but I would guess right-hand thread. I have a tool that'll span and insert two shafts into the drum's opposing holes so I can crank it. No tool for the cog side - I'm using a small punch and hammer, trying to knock it loose. No luck on anything so far. Anyone else run into something like this?
1337676
1337677
Gordon
If it is like most freewheels, you need a remover tool that fits in the two slots closest to the inside, then it should unthread going counter clockwise. I believe the hub is threaded similarly on both sides.
the tinker
Can't these "freewheels" be placed in a vice, and then rotate the rim counter-clockwise, like taking off a standard New departure cog? Never took one of these modern wheels apart.
bloo
I doubt it. Freewheel threads are generally arranged so pedaling tightens. If you put it in the vise and turned in the loosening direction, I think it would just freewheel.
guzziworksman
Looks to be a healthy tool - and I can put breaker bar on it. Any chance someone knows this tool's name. I'll do a search for "freewheel tool" for starters. Thanks, everyone!
guzziworksman
An update. I got the outer ring - a locking flange, I'll call it - off. It unscrews CW. I removed the cog, and about 40 of the smallest ball bearings I've ever seen. I need to get the innermost piece off, w/o destroying it. Replacements are not available. A freewheel tool would fit those two slots...don't have one. The ones I've seen online, give no particular dimensions. But I could order one that looks close and modify it to fit, hopefully. My local high-end bike shop is closed today - I'm thinking of enlisting their help. Until then, I'll try a few more taps with a big screwdriver and a heavy hammer on those slots (CW? CCW?) - but I don't want to wreck anything. The last pic shows the opposite (left) side. That's the brake drum. Laying alongside it, is an old motorcycle header nut tool that'll fit into the opposing holes. You can tell I've been trying - I'm beginning to destroy the holes. I THINK it loosens CCW. I'm hoping that if I can remove one side of this hub, I can slip the whole thing out and access the spokes. Any thoughts? I really appreciate the advice already offered.
1338241
1338242
1338243
bloo
Normally you wouldn't take the freewheel apart like that. I agree. Take it in. You need the right tool and it is going to be real tough with the slots all rounded out like that. Threads should be normal right hand threads like any other freewheel, if they were reverse then pedaling would unscrew it.
RustySprockets
Yeah, the correct tool should have spun that off as an assembled unit. Even when the proper tool is used, it is wise to secure it loosely in place using a bolt passed through the axle hole. That prevents the tool from slipping and ruining the notches...like yours are. They are pretty chowdered.
guzziworksman
Actually...I didn't know I had boogered up those slots that badly, until I saw the pics I've posted. Shame on me. An overanxious rookie. Hopefully, my local bike shop can get me out of this. I'll report back.
guzziworksman
So my update is NOT what I expected. I went to the bike shop. The 20-something bike mechanic spent some minutes searching for a tool that MIGHT fit those freewheel slots, plus a few minutes inspecting the hub. Then he asked..."Why do you want to take it apart?" I said, "To respoke it." And he said..."You don't have to. See how the hub flanges are slotted, so you can just slip the spokes in?" I said, "Oh yeah..." Being stupid has always come naturally, to me. But it's never been easy.
