Hi
@schwinnphantom
Thanks (-: If that's a G519 Columbia, details of it would be of use too.
As you've probably realised, Huffman parts are generally rarer than Columbia, but there is also a little more variation in parts possible than with Columbia's.
I think a first step would be to assess what parts you have.
Just frames? Frames and original forks? Original hubs? Wheels etc.
Than you could assess which is the best to rebuild first. Ideally frame/forks/Morrow hub of the correct date would be the best thing to build around.
Handlebars are still easily available on Ebay, though there seem to be fewer around than there were.
Original hubs are difficult, to find, but it is possible to find wartime dated Morrow hubs with size 13 spokes, so build a lighter weight wheel.
As you can see from my post 32 above, Lobdell rims were an alternative to drop centres used on Huffmans, and are quite easy to find in the size 13 spoke, and easy to drill out to the heavier size 10 spoke.
The frame I see doesn't have the correct chain wheel, but these are available in 'blackout', off civilian Daytons of the period, and turn up on this site for sale reasonably often. The Torrington 8 pedals also turn up here, and you can buy some with poor plating to strip and paint. The wooden blocks occasionally turn up as originals, or reproductions are available here:
http://www.bergerwerke.com/products.html
You may also want to contact
@Krakatoa on this site with your wants list. He seems to be able to turn up a lot of the wartime bike parts.
And there's the 'wanted' section on this site which helps too.
Best Regards,
Adrian
