So I was tearing down my 1953 Huffy 24 inch, and I can see why the chainguard was missing. The crank is wrong and could never have cleared a chainguard. It is also bent.
The rest of the bottom bracket was screwed up as well, and I need to know what I have here so I can go looking or advertising for parts. My question for the Huffman experts is thus: Does ANYTHING in this picture look like 1953 Huffy to you other than the chainwheel?
The crank is wrong, does not fit correctly, and is 5-1/2 inches center to center. How long is an original 1953 Huffy 24" crank?
Note how the inner cone needs a pin spanner to unscrew. Outer cone has slots on the outside like Schwinn, and is marked "10" on the inside. Both have a flat race surface (not a curved race) where the bearings run. Bearing retainers are 10 bearing and open on the outside. They are marked "STAR". The cups don't seem to be marked.
Thanks.
Thanks.
