I need a solid tire for a Briggs & Stratton MotorWheel
Are you sure it takes a solid tire. Coker tire might make what you need just maybe. I would give them look up.
I have some solid 20 inch tires waaayyyy in the back of the barn. I'll see if I can get to them. I know most of them are for Schwinn S7, but if I remember correctly there are a couple that are for different rims.
I found what I have but they won't work I'm afraid. They are 20 x 1.75 but it appears the rim would have to be about 15 1/4 in diameter. Perhaps a tire for a 20 x 1 3/8 would be correct? Was the original tire one of the garden hose variety with the tied wire in the center?
Well thanks for checking. Dave
I'm told that a tire marked United States Tire 20 x 2 would work.
I don't know if this will help with your search, but this is a wheel from a 20 inch tricycle. The rim measures 17 1/4 from edge to edge. The tire is hollow and unfortunately it is worn down to the core in one spot.
1194879
1194880
