bairdco
i just got this little 20" bike.
it doesn't have a headbadge, and the closest thing i can find that looks like it is a Fay Mfg. Co. "Silver Ring Bike-About Jr."
it's got the same sprocket, the same lugged frame style, same measurements, same components as the Fay Mfg. Co. bikes.
New Departure Model "C" rear coaster brake and ND front hub
United States Giant Chain Tread tubular tires
2 piece cottered crank
Torrington 3 1/2" pedals
and i'm pretty sure it's a Troxel seat.
the Fairy Catalog (http://www.ohiomemory.org/cdm4/document.php?CISOROOT=/p267401coll36&CISOPTR=7007&REC=6) from 1930 has an illustration that looks just like it (or, it would look like it if my bike was new.)
looks like it used to have a block chain, and the tires date it pre-33.
serial number is an interlocking "LA," then 22665 then another "LA"
on the spindle of the crank it has what looks like an "I" then 6756 then a triangle with a B (?) inside.
it used to be green and was halfazzed stripped and brushpainted.
tires are destroyed. cranks are shot 'cause the left one was welded on (crooked) so i grinded it off, the fork head tube is bent, and the seat is crusty.
if it's not a Fairy, any ideas? any info at all? is it worth anything more than a hanging decoration at the Claim Jumper?
can i put BMX sew-ups on the rims and ride it?
thanks...
thanks...
