could have started life as a Panther or a Fleet. pretty sure the frames need unique tabs on them to use that tank. chain gaurd and rear rack are wrong, probably more
Looks like a fleet due to lower end stem. Wrong chain guard. It does have a 2 speed automatic rear wheel. Looks like maybe a front wheel with a brake. There seems to be $150 worth of parts
If you are looking to flip it for a profit, then $150 is a bit high. If it is for personal use, then $150 might not be too bad. Two speed rear, front drum brake, decent saddle and slim line tank all add up.
Update,
I was able to get my hands on the wheels from this bike.( My Mom partially disassembled it and sent them to me ! ) The rear wheel appears to be larger than S7. It could be and S2 with a 3 Red Band Bendix . And the front has no marking accept " CMC RIM" with no markings on the coaster brake hub. Is it possible to find the brake lever , cable and for the front hub? The spokes look like heavier gauge
It appears that both wheels will clean up great? Id love to use them !
Thanks for any help wit ID
