AndyA
With A-S 3-speed hub, we'll need brakes fore and aft. Front fork is already drilled for caliper brake. Rear needed modification. I fashioned a little steel clip and mounted it where the fender had been attached. Threads were questionable, so I over drilled and tapped the hole. Might need to adjust things a bit for tire clearance. Can't tell until everything is put together.
