So the tubular forks ended their run on the traveler in '58, with the '59 model picking up the blade style fork. The tubular forks in the 50s were on the world traveler, world and world varsity (as well as superior and paramount, but know one knows anything about those, so...). The collegiate and racer were blade only and world switched to blade in '55 for one year before it transitioned to the racer.
I made a post
here about the years on winged badges.
I kind of disagree that the racer replaced the world varsity. The world was the base model lightweight tourist starting at the same time as the world traveler. The world varsity popped on the scene at the same time as the welterweight as varying options between the base model and top level tourist lightweights. The collegiate was a one year only bike in '54, in lieu of the world model—the base model tourist lightweight—and in '55 the world reappeared then transitioned to racer in '56.
Based on what I am seeing...the winged badge had the silver plating which has started to rub away, so mid 50s. The tubular fork could have been on a world traveler, world or world varsity. It doesn't have the welded on brake cable brackets, so it would not be a model that had hand brakes. One thing I am seeing is no welded on kickstand bracket. However, it does look rough in that area, so maybe it was cut away? The only model with a detachable kickstand in '54 was the collegiate and they all had a blade fork. And if one of the owners could cut away the kickstand, they could cut away the brake line brackets. I would say it is hard to know what it is. I would agree with
@schwinnlax that it is probably a traveler that was not a 3 speed.
