Identification help needed
jimsjunk
On Training Wheels
I just picked up this old bike, The badge reads Treman, King Rapidan Ithaca NY. Which was a hardware store in Ithaca that closed in the late 1930's. Closet I can find to possible manufacture is Schwinn model 103/303 around 1917-1925. Anybody know for sure what it is. There are numbers on bottom look to be B201
Thank You
Jim
Welcome to the Cabe Jim.
I don't believe that's a Schwinn made piece but I'm definitely no expert on these old bikes. Try matching up the placement of the two truss tubes that are between the top and down tubes. Hopefully someone here can help with the ID and maybe post this in the Pre-1933 section and see if you get more responses.
1156013
If, indeed, the machine is a Davis-Built … the underside
of the crankcase will have stampings in line with the
wheels ... not the crank-center.
1156014
Great, that you all for the information, I looked at the numbers on the bottom, unfortunately the run with the crank. Sure was looking good to be a Davis until the last part. I have attached pics of the number
