Some of the 50's Springs are weak or lost tensile strength. A phenomenon called: Spring fatigue. I have 2 55's, a Phantom and Deluxe Green Hornet, that a good even stretch would help. And I'd put odds that plenty cheap A. China springs, for poor tempering and or carbon mixture, require re-stretching regularly.
Albeit, Unless The steel is tempered after stretch, it would return, eventually, to previous relaxed or worse position and or increase potential for crack or break. . In the least, to temper it again, you would need the entire spring glowing red hot ( expanded which would destroy the chrome) and then quick cooled. (shrunk, Chrome flakes off)
A spring is only as good as its temper is or was. . I'd over stretch a fork spring a bit and prob. be fine but wouldn't expect a life time warranty.
