Sold Iver Johnson Project Nearly Complete
Phoenix
KevinsBikes
$400 + 50 shipping. I have an Iver Johnson Mens bike which is close but no cigar. I’m tossing it up here in hopes I find the missing Men’s cranks, or I’m fine with letting someone else finish this one up.
Includes frame/fork/stem/post/sprocket. I have a set of ladies rain gutter fenders and some Ladies Iver bars for $50 tossed into the box if interested.
It’s a 28” - the fork came off a ladies Iver which was the transitional 26/28 and can fit a wider tire no issue.
Are ladies and men's crank arms interchangeable?
I don’t think so. I have a ladies crankset and the offset for the square peg which goes into the sprocket is not the same distance unfortunately.
Got a pic of what you mean?
I have fitted a ladies crank to men’s frame before without issue
The ladies crank AND sprocket fit in a men’s frame no issue. Using ladies cranks arms only with a men’s sprocket is what I don’t believe will line up correctly. The distance to the rectangular peg is longer for a men’s sprocket - so women’s crank arms would not fit.
Interesting - I was certainly wrong then. I tried measuring with it still on the girls bike. I’ll have to find a ball joint remover tool get the one off my ladies bike.
You should have no problem interchanging cranks and sprockets. I’ve used many girls 22T on men’s cranks for riders.
Otherwise girls 28” and 26” used a dogleg crank to clear the Chainguard. Girls are 6.5” long the 28”, men’s are 7”.
I don’t know length specifics on the ballooners.
