JC Higgins colorflow with batwing light question
fordmike65
Riding a '37 Colson Imperial
Mar 4, 2012
16,151
23,581
East Los
#5
Well crap. I guess I needed to do some more homework first. Does anyone have a picture of what the right bracket looks like?
I believe the light you have is rarer than the standard fender mounted Batwing you need. I wouldn't try modifying that one if I were you...
Love of rust
May 29, 2018
24
8
36
Shelby Township, Michigan
#6
Thanks for the tip. I will have to try and find the right one now. A picture of the bottom side of the correct light would be great if anyone has one. Then I know what to look for.
Likes: fordmike65
T.J. Higgins
64
72
Rochester NY
#9
You have the correct bracket already attached to the front fender of the bike. The ends of your bracket are bent down and need to be bent up. The light you purchased has the truss rod bracket. I would NOT remove the riveted bracket from this light. Even if you did this light does not have the dimpled sections on this base and will not work with your bracket.
Likes: fordmike65
Love of rust
May 29, 2018
24
8
36
#10
Thank you for the help. Guess I will be selling this one and am back on the search for the right one.
Likes: fordmike65
Wayne Adam
1,519
431
63
Stillwater, New Jersey United States
#11
Here are several pictures I took back in 2011. You can't really see the bracket but you can see how once installed, you hardly notice the bracket, it is well hidden.
Wayne
Likes: Love of rust
Hammer
Mar 1, 2015
302
374
Coxs Creek, KY, USA
#12
Here is the bracket, as mentioned you already have it it just needs to be CAREFULLY bent back into this shape, I made the same mistake and bought a truss mount batwing and cant mount it to my fender, hopefully you can use this to reshape your bracket, those truss mount brackets can be drilled out and taken off and you can rivet the fender bracket back on to your light, it will still fit the bottom without having the dimples, but you will have to drill new holes, others have told me they done the same thing, but you risk damaging an expensive light, I am looking for another way to mount mine, hope this helps!
Aaron
Likes: TR6SC
$35.00
$162.00
$66.00
$69.95
$35.00
$29.00
$795.00
$48.75
$12.99
$54.99
$749.00
$39.30
$12.00
$64.95
$85.75
$120.00
$150.00
$75.00
