The top tube is not horizontal, it just looks that way in the photo because of the stand under the rear wheel. I think a sloped top tube increases the possibility that it's from the early 1890s. Pope started up Hartford in 1890 I think.
Thanks again for your insight Brian; you are correct, the top tube is angled down a bi.t when the bike is off the stand. I share your frustration as I haven't found another example with the double down tubes. How were the early Hartford's badged? There are no holes for a badge but if you look at the sixth picture down, a halo/ghost shape is visible on the head tube; guessing the bike had a decal here?
The head tube measures: 7 1/4 inches, the seat tube: 23 inches (from the very top, to the metal plate on the bottom just under the rubber block), the cranks: 8 1/8 inches (end to end), 7 " (from the center of the pedal axis to the crank axis). The ghost label/badge outline is approx. 2 1/2 " tall (see drawing). Thank you again for your time and interest in trying to identify this bicycle. I ordered tires yesterday.
