Komet Super coaster brake problems NEED HELP IMMEDIATELY!
The amount of lateral play you show is excessive, not normal. Seems internal parts not seated correctly. You'll need to take apart and reassemble. Similar concept to bendix video tutorial. If first time, maybe one hour or so. Hopefully nothing damaged. Keep in mind inside hub is not symmetrical, one side is wider, so axle assembly goes in one way properly for snug fit. Good luck!
Okay, I got it fixed. Turns out it just needed a little fine-tuning. Got the Komet Hub fixed, and I just finished assembling the bike this afternoon. Thanks for all the tips and advice!
