You guys are moving right to the cutting torch, when maybe some sandpaper would take care of the issue. ALWAYS check the most common problems, or easiest to fix things FIRST before you assume something major is wrong. Yes, IF THE LEG IS BENT, IT NEEDS TO BE ALIGNED.
A Schwinn spring fork leg (any of the three different lengths) is a very strong part. They do not easily bend unless some yahoo thought he was riding a "chopper" and rode the bike without the truss rods installed. The YOKE is simply the very first thing to check on any Schwinn spring fork alignment issue. It's VERY EASY to twist the handle bars and the front wheel being held stationary in say a bicycle rack, the very first thing to bend (even before the rim) will be the S.F. YOKE. It can be off by a lot. and still "not look" tweaked.
Check the Yoke First, then proceed to tearing down the fork legs to check "all three holes" on a flat plate.
Remember, the old guy rule, Band-Aids first, then stiches and staples, and amputations are a last resort. Check the easy stuff first.
John
