LED conversion worthy?
twinflight
Nov 13, 2017
260
Minnesota, United States
www.facebook.com
As you can see, the battery tray, switch and reflector are all that remain on this Silver King. Is this a candidate for an LED conversion or should I stick to restoring the original parts? There are battery trays available but I’m not sure they’ll fit since they’re all marketed to Schwinns.
Freqman1
Jul 14, 2009
18,194
Evans, GA
That tray doesn’t look that bad. I’d clean the contacts, put a bulb in it, and put power to it
Reactions: twinflight
OldSkipTooth
3,407
56
Sebastopol, United States
It’s relatively easy to modify a battery tray, and even add a horn unit. You can shorten them, relocate batteries elsewhere, etc. Once I bought a soldering set it changed everything for me.
twinflight
Nov 13, 2017
260
www.facebook.com
Disregard. We got the light working. You’re right though, the ground needs to be cleaned but that’s it. The only part that needs to be replaced is the lens.
