My first post besides my introduction post. I would like to convert a Delta Rocket Ray to LED; is there a kit or has anyone converted one with LED lighting? If so is there any advice you could give me? Thank You for any help.
R. Clifton
search LED healight I had a how to and even sold some bulbs a while back
the only issue now is the E10 bulb holder blanks are hard to get in lower quantities, I just used an existing glass bulb, broke it and cleaned it out. There is company that sells some foe like 10 bucks but they are not as bright as the one I was making.
I bought several from this website, not necessarily the cheapest out there but they have an informative website and a good selection of white and red screw in bulbs. Even if they're not the cheapest they're far cheaper than when I started looking for them a couple years back and was only finding them for $30+ a piece... http://www.bikeco.co.uk/index.php?mod=productDetail&itemid=454#all
Guess im buying some, you also have to note that we run these with 3v or 4.5v so you may not get the full benefit of the 75lumens due to the due voltage, im sure some math wiz can give the actual out put though. Good price through.
However, if you are doing some real night riding get a good set of riding likes, the cygolite 360 or 500 are great and usb reachargeable, the cygolite hotshot is the best for taillights.
Im all for vintage lights but more for not getting hit by an idiot text-driver!
Just received this bulb from SuperbrightLEDs as sugested and so far I am quite impressed. Fit perfectly in my Delta Rockey Ray fender light. Even was able to retain the spring to keep the bulb from loosening up. Significantly brighter than the incandescent bulb. https://www.superbrightleds.com/moreinfo/flashlight-bulbs/1-watt-flashlight-bulb/373/
