Lines
Ernest Varney
Oct 23, 2016
220
58
Nashua N.H.
Whats the best way to put those lines on the panther chaingaurd, ive tried using painters tape and it goes under it i want clean crisp lines, is there a kit or stencil for this
Reactions: hoofhearted
Freqman1
Jul 14, 2009
19,277
Evans, GA
While you could use Finesse tape and spray it the way to get a hand striped look is to get a good striping brush with some One Shot or other specific sign/striping enamel, paint your stripe, then pull the tape while the paint is still wet so the edges flow out and look like a hand pulled stripe. https://www.finessepinstriping.com/ You may want to repaint that guard to get a smoother finish or you may have bleed through regardless. V/r Shawn
Andrew Gorman
3,021
To keep from bleeding under the tape, shoot on a coat of your base color AFTER you put on your masking. Let it cure, then add your stripe color. A striping brush or a Beugler striper, or even the cheap little glass bottle stripers will work better. Contrary to popular belief, striping is not hard to do.
Sep 2, 2012
12,006
Central Arizona
Is that wat there supposed to look like? Or not look like?
Depends on the era, year and who painted them originally. Yes, those look like factory pins. Here's another factory version going to the end of the indents and then down. The pins never go in the indent.
Ernest Varney
Oct 23, 2016
220
58
Nashua N.H.
I dont understand wat u mean, heres wat mine looked like before i stripped and repainted, is this correct
