Little 1973 Indian 50cc
A friend and I will be refurbishing his first minibike. I'm a bike mechanic, not a small engine mechanic. I could use some advice before tearing into this one. I know how to make it shine, but I don't know if I can make it run. If you can help, or have tackled a similar project and can share some advice or references, please do. Also, the fork is bent, I will be trying to straighten that right off the bat. Thank you!
WANT
I’ll try to get a better pic but the guy I bought mine from has this one he did for his granddaughters has a sidecar.
1686875
Need a matching (or close) 7" long coil spring to replace the broken one. May have just found one
I was tinkering in the shop today and decided to disassemble the rear shocks and give this project a little momentum. Will soak the rusty parts in evaporust and repaint the shock body.
Acquired a ridiculous set of pliers to retrieve the broken end of the fork spring & threaded plug. Welcome to the family, you beautiful little weirdo
I took a year off from this project, but now I've got new momentum. I got this little motor apart and I'm sprucin' it up. I had the block soda blasted to knock all that rusty gunk.
