Long spring seat
Ernest Varney
Oct 23, 2016
220
58
Nashua N.H.
Im looking for tips to redo my seat but it looks like theres only one pan so im confused on how to do this, also does anyone know where to get parts for these types of seats?
Reactions: Balloonoob
Balloonoob
1,292
36
Longmont Colorado
Check out this thread from the Tinker. https://thecabe.com/forum/threads/re-cover-a-saddle-quick-cheap.92195/page-3. It's a fun and helpful read. It's much easier with a dual pan saddle but In Post 45 @Miq covered a single pan long spring. Covering all or the majority of the bottom with leather as clean as possible yielded pretty good results. The post below it shows my re-cover..... In hindsight I should have used a bit more padding for added comfort. The techniques in this thread obviously won't yield a restoration quality result (there are a couple really good saddle restoration guys on the cabe) but they will make it look nicer and get it quite usable.
Balloonoob
1,292
36
Longmont Colorado
Not sure what parts you need... Maybe post in the wanted section with what you are looking for. I would put penetrating oil on every nut and bolt before taking it apart as to not break or strip anything. Good luck!
Ernest Varney
Oct 23, 2016
220
58
Nashua N.H.
Thanks buddy, havent got the seat yet but ya im gonna use penetrating oil and let it sit a day or two the take it apart and do wat i gotta do im hoping to make it look nice the single pan is intimidating as all hell but ill give it a go, again thanks
Miq
1,005
50
Arizona
Ernest,
Keep in mind it doesn't look all that good until you finish gluing and clamping all the top leather. Don't get discouraged, it takes some effort. It helps if you have a plan on how you are going to fold and trim the leather to get a smooth surface before you open the contact cement bottle. :)
You have to clean the rust and get all the pieces as nice as possible before you cover it. I bet it will clean up well and be great on a ratty bike.
This wire frame version has the frame rod formed around the vertical spring posts, blended in with a continuous helical spring, separating it into the top and bottom spring sections. There is a bolt and nut in other versions that allows you to disassemble the 4 separate springs from the frame. So many versions of long spring saddles...
Miq
1,005
50
Arizona
Hi Ernest,
I edited my post while you were reading it. :)
I don't think anything is missing, but the U shaped spring post should be riding under the humps in the seat frame. The zip ties are not needed to hold the posts.
Reactions: piercer_99
Miq
1,005
50
Arizona
Ernest I don't think there is anything you can buy to convert it. The saddle you are showing does not have a frame to accept a bolt and the separate springs you usually see on long spring saddles. The frame arms are weaved into the long helical springs when you assemble the pieces.
Miq
1,005
50
Arizona
(Troxel 1911)
Usually there's 36 and 37 holding two different springs (33 and 34) to a frame (20).
The saddle you are showing has a bent rod frame for 20, weaved into a single long spring.
Miq
1,005
50
Arizona
I think you should try to get what you have working as it is designed. It looks totally functional. I am trying to point out that the springs may be harder to find than the more common seat designs, if you ever need to replace them.
Miq
1,005
50
Arizona
I've never seen a saddle with this design before Ernest. Maybe other CABE members are more familiar with it.
TonyD
In Memoriam
Feb 10, 2020
132
52
Leonard, Michigan
It reminds me of an old Brooks I had. 3 strands and twisted spring wire. Not like a hairpin, way fancier.
The clamp was like a standard old type with the plate on either side with three grooves that the wire frame was pinched in.
TonyD
