Wondering if anyone has come across this before. I have this speedometer component that for some reason won’t turn either way. Is there a way to take this apart and work on it without destroying it. Any help would be appreciated. Thanks.
I had a NOS Huret Speedo kit in the box and the drive unit and speedo was locked up with old grease. I just cleaned out the drive unit and put in some fresh lube.
Hi guys, thanks for your help. I was able to get the retaining ring off and remove the drive tang. The seal holding the worm gear in is very tight, not very pliable. I’m afraid if I try to remove it I’ll tear it up.
