Low Tech Fork Straightening
bikewhorder
So this is the method I use to straighten a bent fork, It literally takes about 5 minutes. The black tube I'm using here is part of a floor jack handle.Most of the bent forks I've encountered are bent @ the steering tube and these are the easiest to fix The tube is slid down to where the bend occurs, in this case is was at the very base. I've also used this method to fix forks that were bent to the side, the only real difference is that you have to install a hub to brace the legs. Unbending bent fork legs can also be fixed like this but the blocking gets a little more involved.
bikewhorder
Hmmmm
It looks like that's designed to be used to straighten forks without removing them from the frame, I don't think I'd try that on any bikes I was attached to, you never know what your going to bend when you just start jacking on a frame like that...
SirMike1983
I've seen the Little Brute used. It works similar to a bumper jack for a car, except in this case you're jacking the fork and pushing it away from the bottom bracket of the frame. It was actually pretty common in some of the older bike shops, but with the rise of liability issues, most shops don't touch fork repair anymore.
Rear Facing Drop Out
another way
I have a good friend that has a used bike shop. When a bike has a bent fork. He replaces the wheel with a 20" bmx wheel turns the fork backwards and runs the bike into a tree. Sounds funny but is surprising how well it works. Then puts the original wheel back on....
bikewhorder
Well there's low tech and then there's red neck, I would say this method falls in the latter...
