CABE Members:
I am building a Path Racer Replica of sorts- Is there some way I can use a lucky seven seat post with say-a modern brooks / persons saddle or copy of a brooks / persons saddle single rail ( round) with a modern clamp? is there a shim or way to do this to make it safe/usable? So the lucky 7 is 5/8" and most of these modern bike clamps are 7/8". What can be done to make this work? Alternativley- can I fabricate a "lucky 7" seat post out of 7/8" round stock? Would that be too much weight added to the frame? The attached pic is from a mid 1960's Schwinn Racer. Could I take the inner clamp (5/8" dia) and use it with the outer clamping pieces of a modern post clamp to use with a modern(ish) double or single rail? Any ideas, suggestions or advice would be appricated. Thanks
