LUXURY LINER HEADLIGHT HELP
SHO2010
Jul 14, 2016
951
61
Ft.Wayne, IN
I picked up this headlight at Ann Arbor show but haven't been able to get it to work. I checked the bulb it is ok, the batteries are fine. It looks like someone restored it. I took some pictures can anyone tell if something is missing or do the connections have to be wired if so do you have a wiring diagram of how it should be done. Thanks for any help.
Cowboy in NC
Jun 12, 2017
827
59
Dunn, NC
Clean your contacts on both sides of the battery terminals with sand paper --looks like silver paint... Check for loose wires...
Looks pretty good- Should work...God Bless--Cowboy
SHO2010
Jul 14, 2016
951
61
Ft.Wayne, IN
I did clean the terminals. there are no wires in there do you know how it should be wired.
Hammer
Mar 1, 2015
332
Coxs Creek, KY, USA
Ok I had the same problem with my Luxury Liner where the light actually bolts to the mount on the bike acts as a ground, I cleaned the mount on the headlight and on the bike itself and the light popped right on and has worked ever since
Reactions: SHO2010
SHO2010
Jul 14, 2016
951
61
Ft.Wayne, IN
That was the problem I recently re-painted the frame and the light had been re-painted when I sanded the paint off light works fine.
Thanks Hammer
Hammer
Mar 1, 2015
332
Coxs Creek, KY, USA
Awesome, glad to be if service, I beat myself up trying to figure that out everything worked fine, and the only thing I had repainted the bucket, looked at the bottom and saw it acted as a ground, took some paint off the bracket and the light and it popped right on, I was hoping this was your issue as well, I just have to have the light and horn working! Have a good evening
Aaron
