Mead Ranger 28” Fauber Crank Arms
Old Soul Classics
In search of 28” Mead Ranger Fauber Crank Arms as pictured , I only need the crank arms and hardware as I have the chaining sprocket already any help would be greatly appreciated.
Thanks Rick
Need inner diameter of the center mounting hole and the center to center spacing of that center hole and 'peg' to hold the chainring in place.
I may have a crankset for you or potentially just a crank arm set, I'll check on your behalf with necessary measurements.
Jesse
This ring was mated with a Fauber crankarm originally. Fauber cranksets were often spec'd on these Meads. Very difficult to see what the rings' crankarm and drive pin opening measurements are looking at your pics. I would simply measure the three key dimensions Jesse McCauly mentioned and write them down here~ Fauber has that patent date on much if not most of their crank hardware. Another fauber below similar.
