Miami Mfg. Hudson Help
John Haeberle
Hi All....I recently bought this great Miami built Hudson which I am doing a thorough cleaning and servicing. As you can see, everything on the bike was painted gray. Assuming this is a mid-teens Hudson, I wonder if it may be WWI....maybe somehow related to the Navy? Lakehurst Naval Base (where the Hindenburg went down) is only a few miles from where this was purchased. Anybody have any thoughts on this? I have included a pic of the serial number.
To finish the project, I want to replace incorrect parts with correct, or at the very least, period correct parts. There is so little documentation about the Hudson bicycles. If anyone has any input with regards to the following, or has any period correct parts that you wish to sell, please let me know. Looking for stem, grips (Miami referred to Boy Scout grips or Keystone rubber grips), drop stand with ears, 28" - 36 hole wood wheel, front hub, double butted 12 1/16" spokes.
Thanks...John
Nice diamond frame bike.
The basket as well as the fender braces look peculiar, in a cool way; (and of course the front wheel is a bit small).
The Fauber chain ring sprocket is one of those with 5 round holes, versus 1 drive pin hole and 4 diamonds.
Gee, this one brings back memories. My father worked at the US Naval Base in Alameda, CA. He was a civilian airplane mechanic and we lived in spitting distance off the base. I recalled as a youngster, he would peddle home for lunch, riding one a “gray” bike (obviously a much later model). But I'm guessing over the years the principles didn't change much for military bikes. The bikes were used as courier cycles for base workers and navy men to shuttle around on the base, or to trek parts around the base or from hanger to the hangers. I also recalled seeing sailors riding them on board the aircraft carriers moored at the Naval station. The one thing, I clearly remember…that these bikes were unadorned...in other words –nothing special to look at! They were sprayed that banal gray color, and all its brightwork was gray as well; head badge, handlebars, even the front baskets were painted gray! I also recollect crude numbers stenciled somewhere on the frame or its fenders ( I guess to track or monitor the bikes whereabouts)? Also, stenciled somewhere on the bike, “Property of the U.S. Government”
You should post your questions on the CABE’S Military Bicycle forum or try http://www.theliberator.be/militarybicycles.htm or http://www.bergerwerke.com/historyG519.html The last two links are more focused on Army bikes…but you never know, there may be a few old sea dogs out there who collect and restore navy bikes?
Best, Carlton
I recall a shipyard worker getting in some kind of trouble, for painting his entire house exterior, (which everyone could see), haze gray.
I love discovery and factoids...for my edification, can you share more information about Fauber's 5 hole chainring...I'm not familiar with this design
1220636
John, perhaps you can check the above
set up and see if there's any stampings on the sprocket and crank?
The early Fauber’s were stamped and the sprocket cutouts were Crowns & Diamonds, plus the Fauber set up offered a proprietary one - piece crank.
1220639
Over the years, production of the 4-pin hanger was discontinued and the chainring morphed into pseudo Hearts and Diamonds
1220757
I believe several manufacturers copied the Fauber sprocket designs. Hence, Fauber stamping their products and running ads about patent infringements and their designs!
1220613
I always thought this Fauber's stamping was a lighting bolt?
1220614
No way! Its a one-piece crank
1220612
Perhaps John's sprocket is a Great Western?
1220642
Yes, GWM Fauber, perhaps pre-war teens.
Looks like another one sold by a member; (from Pandora Ohio?); B-serial number prefix, 45-mm threaded BB, and 1913 patent frame (1916?).
1220775
Note that the holes are of different offsets from the crank shaft, maybe different diameters too(?); not likely that equally spaced diamonds were re-drilled or reamed out.
Looks like John's sprocket was used with a Miami crank (small pin, wider offset than most).
It would be interesting to ID each of those 5 holes: GWM; Miami; Excelsior(?); Emblem(?); and another?
1220779
What years:
I forget in what other post the year that GWM Indiana started manufacturing and advertising Fauber (was Chicago) parts. Perhaps they started with furnished Fauber tools (dies), and "had to do something" to make the holes in the boiler-plate steel sprockets match their own foundry-forged cranks -- as well as other manufacturer's cranks.
I forget in what other post the year that Miami advertised that they made their own bottom bracket hangers, cranks and sprockets.
I generally refer to GWM-built Fauber cranks and sprockets as plain Fauber's (stamped or not), just because I only see the ToC ones in old ad/catalog pictures.
It would be interesting to i.d. each of those 5 holes: GWM; Miami; Excelsior(?); Emblem(?); and another?
What years:
I forget in what other post the year that GWM Indiana started manufacturing and advertising Fauber (was Chicago) parts. Perhaps they started with furnished Fauber tools (dies), and had to do "something" to make the holes in the boiler-plate steel sprockets match their own foundry-forged cranks -- as well as other manufacturer's cranks.
I think it is about '15 when the lit says Miami made their own parts but fairly certain these were still made off the Fauber patent. A lot of mfrs did this by paying the patent holder a fee and producing like parts. V/r Shawn
John,
@Jesse McCauley just bought a group of NOS nickel plated teens/20's period stems that would be correct for this bike; he likely can help you out with a wheel as well. Keystone and Boyscout grips are the rarest parts that bike requires, "hens teeth" status. Marty @cyclingday was speaking to @rideahiggins to have the boy scout type remade; has that project got off the ground guys? It would be great to have the Keystone grips remade. I have never seen any available. I own a set of bars that just have fragments of these grips.
Nice project, good luck with it!
Kindly, Brant
Best, Carlton
I had a feeling it was a messenger bike used around the base, with the basket that was rigged up on it. That's very interesting that they were also used as transportation on the aircraft carriers. I really enjoy researching the history of all the bikes that I've owned. This one is especially interesting being that it was possibly military related, but also because of it being a Miami built bike.
