Here is the perforated bottom bracket shell. Unsure if it was original from the builder, or done later in its life. The holes do not appear to be evenly laid out, and the large one to the front would only serve to catch more water and grit flying off the front tire. Closest I have seen is on early Colnago Supers with 8 small holes surrounding a larger center hole. Regardless, I have never seen that pattern anywhere. I have not seen frames (Italian) with those dimples in the rear nozzles. The frame (mid '70s) is a repaint with Chesini decals. Definitely not a Chesini! Huret front (700 series?) and rear mechs (model?).
