Monark Bicycles
CTony
Hello All.I just purchased a Monark bike and have questions about this bike.I spent 40$ on it but what caught my eyes was the equipment I’m going to up load photos of bicycl.please give me your thoughts.
contract produced in Britain during the 1950's for Monark USA
have seen other examples of these which were done by Raleigh
do not recognize the maker in this case
the last character (symbol) in the seat lug marking indicates the city within California where the bicycle was licensed
California bicycle licenses are granted for a term of three years
if you subtract three years from the expiry date on the blue & silver license transfer you may have the year of original purchase
the machine's Cyclo Benelux Mark 7 gear ensemble launched in 1957 so date likely to be between there and the early 1960's
by the mid to later 1960's this model was coming through with a Huret Allvit gear ensemble; had the opportunity to see in person an example from 1968 which was so kitted
cycle bears no relation to Monark of Sweden
Thank You Juvela.I just read interesting article called made in chicago they had photos of head badges one similar to whats on this bike but no chicago co.So that being said safe to say built in England?I have never seen 26x13/8 (590) bike with style of gearing.Every day is a learning day.Again Thank you.
26" wheel "tenspeeds" were fairly common at this era
frequently produced by domestic Yank perpetrators
sometimes ordered that way from foreign contract manufacturers
as the cycle sits in the repair stand it "looks" like the rear wheel might be a 27 and the front a 26 - your eyes are the ones on the scene...
note for example the position of the brake pads in the adjusting slots of the brake calipers
Juvela I checked on those wheels both are 26x13/8.Rear brake was new tourney shimano.Front brake seems to be original has hook where brake cable attache’s too.will new wheel set maybe a upgrade
value -
cycle not of much greater market value than purchase price
mention this in case you are considering mounting new parts prior to posting for sale
it would be easy to get quickly "under water" with more invested than could be recovered, even counting labour at zero
if on the other hand, you would wish to retain the bicycle either for collection or rider then investing in new fittings of a much lesser issue
wheels -
clearances are so large, both front and rear, that is appears manufacturer may have employed same frame to build models with both 26 and 27 inch wheels
you mention possibility of changing wheels
appears there would be room for either 700 (622 bead seat diameter) or 27 (630 bead seat diameter)
this would be an opportunity to go to alloy rims which would save a bit of weight and would give much improved braking performance
suggest to consider 700 due to the much greater tyre selection the size affords
going with a larger wheel size may mean you could go to shorter brake calipers which will have less flex
bar wrap -
the white plastic tape seen hanging loosely in photo is likely to be GEM brand, if original to cycle
if you would like to stay with the OEM product there are new rolls which come up regularly on ebay and similar venues
chainset -
appears it may be NICKLIN brand
if this the case there will be recess on the back side of the arm just below the spindle hole with a raised letter N in its centre
here is a NICKLIN set done for Raleigh
Raleigh:Nicklin crank arm .jpg
gearing -
in case you wish to consider making a gearing change you will need to stay within the moderate capacity of the Cyclo Benelux Mark 7 gear mech
hope you have lots of fun working with the machine, cosmetic condition appears quite excellent for age, the paint finish should polish up very nicely for you
Monark imported some TI-built lightweights before Huffy bought them (at the end of 1957), and Huffy imported Raleigh lightweights under the "Huffy Sportsman" label up until sometime in the '60's. The lugs on this frame look like a Raleigh, so I'm guessing this was imported after Huffy bought Monark. Compare it to the Huffy Sportsman "Model 398" in this 1961 Catalog:
Lines right up she do! 😁
