SKPC
^^^^^^ See above comment....1st things 1st. Look closely at your last pic of the head tube. The bearing cone is not parallel with the headset cup! Looks to be 1/8" higher in the front, which means the head tube is very damaged and out-of-true. This will cause even more damage if you run it like this.
For the frames' wellbeing and to solve the problem once and for all, get the top and bottom of the head tube professionally "shaved". A special tool is required to do this. Any bike shop should have one. Slapping a weld and hitting it with a grinder will not cut it. What does the bottom of the head tube look like?....
