Monark #s prior to 1941 #s deeply punched under crank housing.
3600 or under....1934
3601 to 8100.....35
8101 to 9126.....36
9127 to 11019....37
11020 to 30000....?
30001 to 46001....38
46001 to 62000...39
62001 to 79000....40
79001 to 100761....41
100762 to 112911...42
112911 to 118000....?
#s on aluminum tag : starting in 1946
118106 to 286500....1946
286521 to 429919.....47
429920 to 539000.....48
539001 to 737063..... 49
737064 to 827982.....50
827983 to 950701.....51
950702 to 1387335.....52
1387524 to 1762369....53
1762370 to 1911106...54
1946 -47: horn button is on left side of tank
1948-49-50: button on right side
1951- 52-53-54- small button on top right of tank
1946-49 pedestal light
1950 .....train light
beginning 1953 single horizontal springer
I double checked this info . If anyone can add anything or finds an error please amend
Also ,be aware if you are adding or replacing a springer fork that the forks are deeper on the post war bikes that are equipped with deep fenders. Also the two threaded rods that the springs set on may be longer then the pre-war and early post war.
