From a 1964-66 chrome Monark SIlver King - this is the era when Huffy took over so I bleieve will also fit similar Huffy branded bikes, but check the pics.
Rack - includes all parts, including fixing bracket and screws. The bracket attaches to a mount on the rear fender and the stays to mounting points on the frame, the front attaches to the seat clamp - see pic of it fitted.
Great for restoration - Can't verify if light is working but it's simple enough. Missing a rear red light cover
Tank - includes all parts, including fixing brackets and screws
Great for restoration - everything is here, but the horn switch has become separated, one of the wires seems cut and I can't verify if the horn/light are working.
Fender ncludes riveted stays which screw onto frame, reflector and fittings for the rack that goes on top. Comes with screw and bolts
Lots of pics here - https://www.dropbox.com/sh/3p7oaxgbrhingz0/AADSAvecvyaKa0Xgff3ULEJra?dl=0
May split, note shipping is from the UK so will be added, and will likely be high to US, the fender really pushes it up due to size, the other parts are not as bad.
