okozzy
One of my new rescued bikes has a very worn out morrow clutch sleeve (brass splines that contact the hub shell when the brake is applied), these are hard to find in a NOS condition.
Has anyone successfully tried to re-groove / re-etch the pads, if so what did you use and or what method did you use?
Picture below is not the actual picture but just an example of the sleeve....... mine are completely smooth.
thank you!:eek:
thank you!:eek:
