It reminds me of a bike one of my friends had somewhere between '78 and '80. If it is the same bike it came with a one piece tank seat and rear fender combo. I thought the model might be a Huffy MX, I did a couple of searches and found stuff similar but not quite identical. Possibly a Reliance Motobike?
It's a Graco. It looks like it still has the original 22" front rim too. finding a new front tire may be a pain. You may also have trouble finding proper grips too. the tubing used to make the bars is 3/4" od and not the standard 7/8.
I think you be right because it does have a 22 inch front rim and the handle bars are smaller. If anyone knows where to find a tire and grips let me know.
You are right about the front tire and handle bars so it must be a graco. If anyone has more info and pictures on this bike I would like to know.I will also be needing some parts if anyone has any.
A lot of standard grips will stretch, bring it to a shop and have them put on a pair. As long as you arent too picky about the grip, itll be easy to find.
Um standard bars and grips are 7/8 of an inch. The bars on this bike are 3/4 of an inch. 7/8 is larger than 3/4 so the majority of grips available are too big to fit these bars.
[I found a new nobby tire at my local schwinn bike shop for $25.00. It is a 22x1.75 that should work just a little skinny. I think I found grips on a gas powered garden cultivator they look smaller than regular grips so i will try these. The next thing on my list is to find a plastic tank even if it is not a graco I think I can make it work. I believe I bought a plastic tank for my bike at K Mart back in the 70's which would work if anyone might know where to find one let me know.
