Murry built Hiawatha
mrg
Always try to build something differen every year for the San Fransisco ride with gears and tool box tank to keep some stuff ( tools, tube, little pump etc. ), we usually ride and take the Bart from across the bay so we end up doing 25-30 mi. with hills on Sat ( usually a different shorter ride in Marin on Sun. ) so just got my 40-41 curved bar together, don't know if any curved bars a a tool box door so I used one off a Mercury pod bike, tanks are a little different for straight vs curved seat stay frame so only used the door side of the straight bar pod bike as to not have to modify both side. used a 7 spd wheel set with a 30 tooth gear I made so I could still run a full size 1/2 " Murry front sprocket. have to do shakedown rides the next few days to ck for any problems and of course the seat I picked up for it has a broken spring and have to decide if I want to run some aluminum fenders ( it's no like it's going to rain! ) and the rear rack to carry a bag, wanted to strip the frame and run some different tires but running out of time.
1668771
1668772
1668773
1668775
1668776
1668777
2017
1668782
2018
1668780
2019
1668781
mrg
OK, 2 days before my trip was having problems with the seat post not going in far enough, weather there's slag in the, been repaired or frame bent from post being to high so I messed around with it and frame started cracking, was going to get it welded but have to deal with the seat post not going in enough so rebuilt the whole thing on a backup frame ( Collegiate ), has a couple of holes drilled including for a kickstand but not the seat post goes in almost 10" even with the curved frame, tried a little smaller front sprocket so I won't use that worn out 3rd and get a pretty low 7th for those SF & Mt Tam hills!, hopefully it's ready for 40-50 miles in 2 days!
1670477
1670479
1670481
1670482
1670483
mrg
3rd gear had a little skip but with 6 other gears and a 30 tooth rear made it up some big hills, and down Lombard st. ( without overheating the brake! ) on our 20+ miles bridge to bridge ride, had a tube, tools & pump in the toolbox tank but no problems 😎, already thinking about next years SF ride-build 🤔
1673516
1673517
1673518
1673519
1673520
